Best way to bleed air out of loop?
is it all in the case?
is it a T-line ?
leave the pump on over night, and rock the case every now and again (and the rad) -when the pc is off, it'll go eventually
All in case using a bay res. Most of it seems to be gone just a few niggly little air bubbles remaining.
Funny how a post about bleeding has a poster with the name bledd with the first reply. :p
i normally run mine up outside the case, and jiggle it around with the res at the top.
if you have a thermochill rad, they have bleeder screws too.
If the air is in the res, fill the res! If the loop is largely full, turn off the pump and wiggle the case around to move any trapped air up to the res. Run the loop in short bursts, then move the case around. Repeat.
Or just leave it running, occasionally adding water to the res as required. Bubbles in the stream have very little effect on cooling.
