Caporegime
- 30 Jul 2013
Howdy.
I've been working from home since March 19th and my wife worked from home anyway.
Until now, my wife and I have both been in the lounge as that's where she is usually setup anyway and that's where my gaming PC is.....but working so close together when we are both answering calls in completely different jobs has been a bit of a nightmare.
So i've put together new desk upstairs in the front room, but it's literally the other end of the house to my Asus RT-AX88U router.
It's a small house, so I thought it would be fine and I had provisionally tested the Wifi using my Samsung S20 Ultra which is connected via 'Wifi 6', and that's super speedy.
But I put my Surface Pro X up there (which doesn't support Wifi 6), connected to both the 2.4 and 5Ghz networks and the internet just isn't working very well at all.
I know that the Asus RT-AX88U is a 'Mesh' router, but I don't want to have to spend another £230 on the exact same router and use it as a Node, if I can buy something much cheaper to do the same job.
Please help!
Please help!
