- 7 Mar 2005
- LU7
I have a WRT54GL router running the Tomato mod in my bedroom which is in the basement!
It is currently set to channel 11 but using an app on my HTC Magic it seems that channels 1 or 14 would be a little less busy so I might change to that.
Anyway I'm thinking of buying a netbook soon and it'd be nice to use the netbook in the garden and access the Internet through my router. The signal drops quite a bit going from my room to the garden so I was wondering if I could make the signal a bit stronger to make the wireless performance of the netbook a bit better.
The way I see it is that I can either buy new antennas for the WRT54GL or, having looked on the router, increase the transmit power from the default 42mW to something a bit higher. A quick Google shows that anything above 70 is pushing the limits of the hardware a bit and that above 84 the chip is getting friend.
So is there a recommendation on which method is better? New antennas or increase transmit power or should I try both out?
