- 16 Nov 2008
- West Midlands
My monitor is filthy I wont use anything like water as it will just make it worse. Anything i can buy with is decent and will clean it thoroughly.
I posed this very question a few months ago and the answer is simple and cheap.
Go to the supermarket and buy a microfibre cloth. They are less than two pounds. Wet part of the cloth and wipe it over the screen gently it will pick up everything. Then just gently dry it down with the dry part of the cloth.
These microfibre cloths are very impressive.![]()
Tried that it leaves streaks on the screen. A microfiber cloth alone is not good for the job.
