Best way to clean Razor mouse
Permabanned
26 Oct 2002
Reading, England
What's the best way to clean the rubber coating the Razor mice have?
Mine's getting a bit grubby and need to clean it without damaging it.
Thx.
unplug, wipe down with a cloth and diluted Stardrops, dry and plug back in would be my suggestion.
Alcohol and rubber might end in tears.
What would you wipe it down with? because that rubber surface picks up any fibers of most cloths I try to use.
Try the same stuff you use to clean glass lenses and TV screens if you have that laying around, I think it's called lintless microfiber or something like that :P
