Best way to clean screen
14 Oct 2009
UK
Basically the title....what do you guys use for cleaning your screen? i have tried a microfibre cloth but its not doing much :/
Cheers guys
autoglym fastglass and micro fibre cloth do it with plasmas and tn's,tft's and results are perfect it uses a liquid that air dries and it does not affect the screen in anyway
I have cleaned the plasma litterally hundred of times with this method i have a 2 year old daughter that thinks the screen is her own personal drawing board :)
cheers mate, where do i get that? is it fine to wash a microfibre cloth? as mines looking a little dirty...its going to be used on a netbook so will that still be fine?
yeah washing machine 40 degrees with biological washing powder i've had mine about 3 years
fast glass u get from halfords
*edit* yeah i do my 2 laptops with it aswell really makes your screens sparkle just spray it on wipe it back and forth until it dries out takes about 30 seconds then when you've done use it on the car (bonus lol)
Microfibre cloths , are they like the little things you get to clean glasses?
No they are different they hold dirt in the fibre of the cloth to stop it being spread around the surface your cleaning quid shops sell them usually 2 or 3 for a quid don't buy the 15 quid one from the car shop cheap one is just the jobbie
Microfibre cloth and luke warm water, no need for fancy chemical products, as above, dont buy the fancy 3m cloths from car shops, you can get packs of microfibre cloths in your grocery shop for 3 or 4 quid. Dip them in warm water and they do grand, been cleaning my benq 24" lcd monitor, my 20" viewsonic monitor and my lcd telly for ages with theese cloths.
Hi Guys,
This is my first OcUK product so Im in your hands
Will this fastglass be ok for my syncmaster p2450 monitor which Im chuffed to bits with.
Cheers Alan.
+1 for Autoglym Fastglass does the monitor tv everything :D, use it with a clean bit of soft cotton rag like an old tshirt cut up.
missus even uses it to clean mirrors :rolleyes:
Off topic: How do you get rid of de-pixelated pixels on the screen? I have 2 green pixels just sitting there :(
I use a microfibre cloth. I damp some of the cloth, and wipe the screen with it, and then wipe over the screen with the dry part of the cloth.
