Best way to clean?
8 Jun 2006
Hertfordshire
Hi all,
I have purchased some Artic Silver 5 compound and I would like to clean the standard stuff off that came with my heat sink!!
Whats the best way? Spirits or just a dry clothe?
Then do I just put a blob on the centre of the CPU and place fan back!!
Cheers ;)
CPU running at 38-40 unloaded!
Edit: my fan is a - Zalman CNPS9500-LED Aero Flower (Socket 939/754/478/775) CPU Cooler (HS-015-ZA) from OcUK
Put a grain of rice sized glop of AS and use something thats lint free (like a plastic glove) to spread the AS evenly across the processor.
