best way to cleanba radiator?
12 May 2011
Southampton
This might be a stupid question but can I pour water through my radiator? I.e. from top to bottom, to clear out the dust? There isn't anything electrical involved, once the fans are removed right?
How do you clear out a radiator? I'm using an h100i
probably avoid the water route. Will make the dust it doesn't shift stick to the rad and you'll have to dry it off before putting it back in your system. Tbh an air compressor / can of compressed air + a soft brush should do the job
Hi, with my custom loop 560 rad been externaly mounted under my desk in the foot well. Once a month l give it a quick brush all round and a blast of air from a small air pump for inflatables.
I bought this a couple of years ago for about £12 Sidewinder Air Pump 240v with 3 nozzle sizes and it does work very well l must say.
I must have saved a small fortune instead of buying Air Dusters at about £8 ago, apart from our house having 3 PC's alone.
