I'm currently trying to setup a 3 display system for someone. They have two 19" monitors with DVI inputs, and a 40" TV with HDMI inputs.
2 graphics cards in the PC is not an option, so I think the only way to go with this is with one of the new ATI cards and using eyefinity? The only problem I can see is that if you want 3 displays, one of them has to use the displayport.
Do OC do an adaptor so I could use the 2 DVI outs to drive the monitors and run and HDMI cable to the TV from the display port adaptor? Would this definately work?
VGA is out by the way, currently two of the screens are running off VGA and are to blurry for the user.
Cheers!
Cheers!
