I also need/want dvd/ps2/original xbox to be connected to the tft too.
I currently have a 4 to 1 scart switch box, with the above things plugged into it.
Would the best way to connect the 360 be a VGA 306 lead, into a VGA switchover box.
And then the scart box, also into the vga switcher using a scart to vga converter, if you get me.
Or, the easier solution is plug the 360 into the scart box, and then just use a single scart>vga lead to the monitor from the box, would i loose much picture quality from the 360 doing it that way?
