Best way to connect a monitor to the GPU
27 Dec 2012
London
Hey guys, I was wondering which is the best way to connect my monitor to the gpu since I don't need it's audio as I have separate speakers. I'm currently using HDMI but It also has VGA and DVI port sooo, which way would give a better quality ?
P.S: I also have a secondary monitor of a smaller resolution which is connected to the motherboard since I don't have a VGA slot on my GPU ( and i need to buy a cable if I want to go for DVI since it doesn't support HDMI) Is that a bad thing to do ? having a monitor connected to the gpu and the other to the mobo? :D (I only use the 2nd monitor for media and such while gaming)
