Best way to connect a NES to a pc?
2 Jun 2003
Nottingham
Hi,
I have a NES and I am wanting to connect it to my PC. It is a modern pc with a tv card too. What would be the best method to do this?
Ariel cable from the NES straight into the antenna port on the tv card should work fine, then scan to I think, channel 36 or 37? Should show up around there :)
The NES has a composite video output and a single mono composite audio output (*check the side of the console). you should be able to plug the composite video output into any VIVO graphics card or TV card that has video inputs for retro goodness :)
*Unless Ninty decided to remove these off the newer revisions of the console??
