Hi - Sorry if something similar already posted.
Got 2 monitors that I want to use in tandem whilst working from home - 1 x AOC G2460PF (primary) & 1 x BenQ GL2460 (no DP) with an MSI Frozen II 960 GTX (1 x DVI, 3 x DP, 1 x HDMI).
What would be the easier and most optimum way of connecting these 2 monitors?
In my head options are:
1) HDMI (Gfx card to AOC), then DP -> HDMI (AOC to BenQ using DP/HDMI adapter). I.e. daisychain 2nd monitor using adapter - can you do this?
2) DP (Gfx card to AOC), HDMI (Gfx card to BenQ)
3) DVI (GFx card to AOC - existing set up), HDMI (Gfx card to BenQ)
Thanks in advance!
Thanks in advance!
