I really want to know the difference between all the connections. like HDMI, VGA, DVI etc. What one is the best? i have ordered a BenQ G2420HDBL 24". I have had a previous Samsung SM2333SW which went faulty on me and i dunno what caused it. I just want to make sure im using the correct cables etc for when i get the benq.
Should i use a normal VGA cable with an adaptor ? do i need anything special to run HD?
be aswell going for DVI to DVI
