best way to connect x-fi to logitech z-5500
Can connect it up a few ways:
The orange, black, green cables (3 stereo jacks) from the back of the sound card to the control centre.
Or Optical (tos link) from the front 5" module to the control centre.. if you have the front module. Optical is good for movies as it lets you use DTS and DD.
the z-5500 comes with the cable to connect the 3x3.5mm stereo jacks from the soundcard to the speaker control panel, this is what i use as i have PS3 hooked up via optical and freeview hooked up to coax... works a treat
