Best way to convert VOB to avi?
30 Jul 2004
East Sussex, UK
Howzit guys.
What is the best program to do:
  • Convert VOB files to AVI files
  • Join the converted VOB files to one single AVI file.
At the moment, I am using Format Factory, it works okay but it takes a stupid amount of time to convert files. WINAVI used to be able to convert and join VOB files in one go to a single AVI file.
However it doesn't seem to be compatible to Windows Seven?
Any help?
Thanks gents! :cool:
Have you tried running winavi in compatibility mode? is a question that some people asked and he tried it and said it worked. that was for vista try it with windows 7?
