Best way to delete everything?
1 Mar 2018
So I'm gonna get loads of new parts for my PC but I'm gonna keep my SSD and HDD as they're not even a year old. What would be the best way of moving them to a new motherboard? Should I just build it, start it up then reset the hard-drives in the new gear? Or reset them in my old PC and then build the new one?
The thing with resetting on my old PC is that bringing up reset in the settings says it will reinstall Windows, but I don't want that for old mobo.
PS. I plan on using an ISO USB to install Windows 10 on my new PC.
Hi Alex.
Just move them to the new system. Boot from the USB. Remove the old partitions on the boot drive (presuming the SSD). Install and boot to Windows. Format the hard drive.
You could format the hard drive in the old system if you wanted to.
Hi Alex.
Thank you. Will formatting my hard drive be done during installation or is that something I have to do within Windows itself? If so how do I do that?
When you delete partition and create new one usually thats when the reformat happens. Then you install windows onto it.
Hi, I apologise for the late reply, but I plan to install Windows 10 on my SSD. I will also have an HDD installed however. Will that also/will I have the option to wipe it as well?
You will only have the option to wipe the OS drive.
Formatting a second drive is incredibly easy these days. You can literally right click > Format > Quick Format
If the drive is empty, or you want to keep the contents, you needn’t even do that.
Thanks for your reply. So formatting wipes it? There's an option called "Allocation Unit Size" When i bring up the menu. The options are 4096 bytes; 8192 bytes; 16 kB; and then each one doubles the previous opiton up until 2048 kB. What one should I pick?
Just put your SSD in when installing W10
Then add the hdd AFTER W10 has installed
Windows can have a nasty habit of installing files to the other drive a swell as the OS drive
