- 24 Jun 2011
- Nuneaton, Warks
HIS IceQ 7950 Boost, using MSI Afterburner and Heaven?
Still pretty new to overclocking.
Not really comfortable with increasing voltages until I know a little more about it.
What would be an expected max overclock for my card using stock voltages (I understand all cards can vary a bit)?
You should quite easily reach 1000MHz on the core, 1350MHz on the memory. Just run Heaven after each bump for a loop or two, and if your temps are okay and you don't see any artifacts/snow then you're good to go. If you crash or hard lock up, then you need to raise voltages or back it off a notch.
As for raising volts, if you're conservative (under 1.2V on the core) then you won't have any real risk if your temps are good (<-- this will be your limiting factor). I ran my 5850 with a balls-to-the-wall overclock for 2 years and it's still going strong.
