As I'm sure you all know, 4.1 jailbreak is almost ready for release and works in the same way as some of the older jailbreaks.
My question is, what will happen if I go from 4.0.1, upgrade through iTunes, then jailbreak 4.1. Will I lose all my Cydia applications I've installed, or will they all re-appear when I jailbreak 4.1?
What would be the best way to do this? Restore a 4.1 image, restore my backup from iTunes (which won't restore any Cydia files/applications I assume?), and then jailbreak and reinstall Cydia apps from there?
I guess the above would be the cleanest as it would remove all traces of the previous jailbreak and Cydia files?
I'd really like the cleanest way of doing this, but don't want to lose my official apps or settings. I don't mind losing my Cydia stuff.
Thanks.
Thanks.
