I have a Virgin Media supplied 'super router' which is fine, I have no issues with it, apart from the signal.
There are black spots in my house on the other side due to what I guess is a range issue.
I have looked at all of these WPS based WIFI extenders and I was wondering if there is a better solution. I had CAT6 wired into all of the walls when I had the house wired and there are network ports all around my house. My question is thus;
Should I just buy one of the extenders which plug into a socket and be done with it?
Or is there a better solution seeing as I have CAT6 terminals around the house which are not being used.
I assume I would be better off with something that would plug into a CAT6 terminal as that would give a direct feed to the internet connection. My fear is that the WIFI extenders are not going to give particularly good performance.
Could someone give me a link to what they would recommend on overclockers?
Cheers guys!
Cheers guys!
