Best way to install latest driver s for ATI card.
I just uninstall the old ones using add/remove programs, but if you want to be sure everything is gone download ATI driver cleaner. To be honest I’ve installed them over the top of old drivers before and its been fine though so I don’t know if it’s really that important anyway.
By the way there is some serious problems with the 7.11 drivers and Quake Wars at the moment if you happen to play that.
