Hey guys!
I would appreciate any useful infomation on how to setup my Philips Hue Play Smart Light Bar with dual Monitors.
I've just got the Philips Hue Play White and Colour Ambiance Smart Light Bar (2 of them) running vertically with the included table stand which looks great just behind my Acer Predator 32" 4k monitor.
However directly next to this, I have my 27" Acer Predator gaming monitor.
I really want to integrate some more Philips Hue Play White and Colour Ambiance Smart Light Bar with this.
How should I do this? Should I get an additional...
1. 1 x Philips Hue Play White and Colour Ambiance Smart Light Bar.
And place the Light Bars behind on the far left of my 27" monitor, one on the far right of my 32" monitor and one inbetween the monitors and treat it is a primary display in the Hue Sync settings?
2. 2 x Philips Hue Play White and Colour Ambiance Smart Light Bar.
And just place them behind on each side of the monitors? If I do that, would it be too bright in the middle?
3. 4 x Philips Hue Play White and Colour Ambiance Smart Light Bar.
If you see my included photo, you will see a weird shadow directly about the 32" monitor. I am thinking of countering this shadow by using the above in 3. and placing one Smart Light bar center horizontally just behind the monitor.
4. 3 x Philips Hue Play White and Colour Ambiance Smart Light Bar.
As above in 3. but instead of having two on them in the middle have just one. So it would be like far left and far right monitors will have one Smart Light bar at the top and side with one inbetween the middle of the two monitors.
I apologise for the long post but this has had me confused for weeks.
How should I do this or do you guys have a suggestion?
Guys it's over to you... All replies much appreciated!!
