Best way to monitor hardware temps in game
4 Dec 2009
Worcestershire
What is the best way to monitor hardware temps of components while in game (mainly thinking about my GPU). Is there a piece of software out there that gives you an overlay in games showing you your temps (similar to fraps but with temps)? Thanks
Everest has an OnScreenDisplay feature (although i never used it) that you can enable to be on top of everything. I will check if it works over full screen games a little later.
