best way to mount bike camera
20 Oct 2006
London
Hi all,
I recently bought a camera, its a slim bullet type camera, that doesnt have any mounting accessories.
The camera is made from plastic.
any recommendations of a strong way to mount it to bike handle bars.
I see people using velcro but doesnt seem reliable.
I was thinking of using epoxy resin a m6 plastic screw and using 1/4 tripod mount on a gopro/garmin out front adapter.
the camera is the http://www.gearbest.com/action-cameras/pp_360146.html
its has a gyro image stabliser and its got good reviews from the RC quadcopter community.
Doesn't have any mounting accessories? That's a bummer.
Erm, a cheap eBay out front mount and duct tape? Did you buy it specifically for cycling?
Yes i wanted something discrete that didn't look like a gopro or camera.
i need some sort of adaptor i can stick on to it with epoxy resin that will attach to like a gopro mount to detach on and off when required.
i might just buy a 1/4" thumb female thumb screw and stick it on the camera.
that way i can use a tripod with it when not using it for cycling
I'd try to fasten it to a Garmin male mount, rather than directly to the bike/bars/stem and then attach another 'out in front' Garmin mount.
i cancelled the order and got the sjcam m10 +
it has gyro and comes with lots of accessories as default when you buy it standard.
