- 14 Jul 2005
- Birmingham
Hi all,
Just trying to figure this out.
I have a standard slotted concrete fence post with 6ft wooden panels, spaced 6ft apart.
I want to mount a galvanised wire framework to a length eventually spanning 6 panels long, i.e starting on post 1 and ending on post 7. But to start with I only need it to span two panels, three posts.
Im aware that basically I need some galvanised wire, vine eyes (or similar), turnbuckle (or similar) for tensioning.
But Im not sure how to mount it. The wire and turnbuckles are relatively cheap, but the mounting options aren't.
Initially I considered these metal brackets at £18 for 6 pieces. https://www.rivelinglenproducts.com/wire-anchor-size-1-132-p.asp They will fit my posts, and is a no drill solution. But Im not sure how strong the metal will be once tensioned and there's no information on whether I need to run intermediate brackets, or just one at either end of my short or even eventually long runs of wire.
An alternative is mounting a wooden treated post 4x2 to the existing concrete post, requiring drilling the concrete post probably in three places and screwing together. Then I could use a standard screw in vine eye easily, but a wooden post 2x4x1.8m is not cheap either and I would presumably need one per concrete post or would I only need one at each end of my run?
Third option is drilling and screwing in vine eyes directly to the concrete post but this doesn't sound like a good idea to me.
Or option 4, screw in vine eyes into the wooden panels themselves, near the edges where there is framing? I could reinforce the framing of the panel with some 22mmx38mm treated timber batten (my panel design allows for this quite easily), but even then a pack of timber is around £40.
Any one got any better ideas?
