Ok another strange post proberbly but this one has a diagram...
Diagram Here
Which is the best way to point a Zalman 9700 aero flower CPU cooler (when i get one) to get the maximum cooling? It will be in an antec 900 on an asus P5W DH, with a QX6700 Quad core (when i get it all).
The diagram shows the big 200mm fan on top and the back 120mm fan along with the chipset heat pipe
1) pointing up the big fan would suck air through the cooler with the back fan pulling air accross the cooler and chipset heatpipe.
2) pointing to the back the fan would suck less air through the zalman but both would fascilitate air accross the heatpipe and the big fan across the top of the cooler.
Hope i have explained this understandably, i cant weigh up which would be the best as both have advantages
Just incase anyone needs to know I do intend on overclocking
Thanks in advance
Diagram Here
Thanks in advance
