Best way to put movies on my ipad?
18 Oct 2002
Newcastle, England
Seeing as this thing has no USB connection what's the easiest way to put movies I have on it? :confused:
Well if you want to stream them then air media server is great. If you want to transfer them then iTunes? or some thing like Dropbox.
And it does have a USB connection, take it out of the plug and stick it in the computer :p
Lol yes of course it does haha. I was thinking in terms of sticking my USB key in, can't do that. I have Dropbox, il try putting one in there thanks.
Get a copy of AV Player HD installed on the iPad. This allows you to browse to the iPad using a web browser on your computer and transfer the movies across that way.
