I have not done this myself as i found it to be too expensive for me, but from what i found you would need a pci card similar to BlackMagic Intensity Pro HDMI Capture Card. These type of card will probably set you back about £100.
There may be other ways to get 1080p, but the reason i wanted hdmi was not just for 1080p, but because i play my consoles on a pc monitor so cant use a component cable as i have no tv to plug into although i did try component/composite (not sure which one lol) to vga, but turns out that doesnt work without a converter box /facepalm.
