Best way to remove protective plastic from acrylic bath
11 Oct 2008
Hi guys. I'm trying to remove the protective plastic from a new acrylic bath tub and it's proving rather difficult. So far I have tried white spirit and a sticker remover but it's not really working. The plastic is almost like cling film. Does anyone have any ideas?
mustard..........
or try hot water. I think thats what i used to remove the protective layer from a new sink I bought a few months ago
heat it up then find an edge and peel it off , it should all come off in one or two pieces really , maybe peel it slower...
Acetone! I had the exact same problem - I tried hot water, scraping, soaking, and nothing worked. Then I saw a post in a different forum suggesting nail polish remover, and voila! The film peeled right off!
Nice necro first post
