Hi There,
I have an Asus z97a mainboard which says its capable of running 3 screens on its own but I would like to install a separate graphics card as the mainboard only has 16gb of memory installed and I don't want to take a chunk out of it.
I don't run heavy games but do play some so would like a bit of quality but also taking price in to consideration.
These are the screens I want to use.
Packard Bell Viseo243D
AOC M2870VHE
Samsung 47" TV
Possible add a 24-28 inch monitor later.
I have been advised that it would be best to install 2 g-cards. If I install them will I be running them independently? am I right in thinking if I link them (SLI/Crossfire) then only one set of ports on the cards will be working, all it does is utilise the processing power of both the cards to one set of outputs?
Just to recap basically I am asking what would be the best solution to run these 3 screens and possibly add a 4th 24-28 inch screen at a later date.
AOC M2870VHE
Samsung 47" TV
