- 25 Sep 2003
- Manchester
I've got some of those little tack things with the half loop that you hammer on to the skirting board but was wondering if there was a better way of doing it?
Do you have a link for some?If you want to do it properly you can get skirting board that is hollow behind which you can run cable through
If you have carpet you can get flat speaker cable and run it under the carpet.
A[L]C;13226174 said:Do you have a link for some?
