- 13 Sep 2010
Sorry if this is posted somewhere else, did a quick search and couldn't see it...
Got a 7900XT, just recently got a monitor (Dell G2724D - 165Hz, G/Freesync)....
How should I set this up to make proper use of it? - Since getting the monitor I've mostly been playing ARK: Survival Ascended, VRR/Freesync is enabled, the fps I'm getting is well within the tolerance for that game. (40-60fps and usually showing around 2x the in game fps on the monitor HUD (when below 60fps)
If I was playing a game where I was getting above that, or above 165, how would I set this up to make sure it is locked to VRR/no tearing?
I found the 'Max FPS' option in the adrenaline suite - Should I be setting that at just below the max Hz of the monitor (i.e. 164)?
Is there anything else I should be setting?
Cheers!
Trojan
Cheers!
Trojan
