Best way to set up Monitor (MB sockets etc)
16 Oct 2008
Hi first off all i hope i have placed this in the right place, i was unsure if it should be here or MB but i think this is right if i wrong sorry mods can you move it for me.
OK down to my issue i have an older Asus Z87 Deluxe Motherboard with an older bios of 2004 but i don't thnk that is relevant here, my monitor is a BenQ BL3200PT, also my TV is a Sony 46EX723.
TV has 4 x HDMI sockets and a VGA socket for PC input, so up until now i have had a 15m (distance between PC and TV) HDMI cable going from MB to the back of the TV, and i been running the monitor by using a "StarTech DP2DVIS DisplayPort to DVI Active Adapter" which i think is the normal size not the mini, but i'm not 100% sure as i have not pulled it all out yet as she has 8 or 9 drives in and she weighs a ton, but i'm running out of HDMI sockets on the TV and need to route the PC signal into the TV via the PC/VGA socket and hence free up anothe TV HDMI socket, but while doing this i want to find the best way to run the monitor from the sockets on my MB.
I'm in a real pickle here, Any advice on the best way to sort this would be welcome, on sorting out both the TV issue, ie; need to supply PC's image on the TV) which i need to do via vga, MB has no VGA but monitor does and also best way to run the monitor from the PC, not a gamer so anything good enough will do does not have to be superduper.
If you need any more info just ask.
All1
TV specs can be found HERE
Monitor specs can be found HERE
Motherboard specs can be found HERE
