I want to get 6 radiator fans down to a single 3pin connection so its all on one control in my new case. I found a 1 to 6 connector but it has direct molex power and I assume that will override the voltage reduction of the fan controller.
Will the single fan controller connection be able to run 6 sp120 fans without the molex. If so Am i better to get the one with a molex connection and just not use it or daisy chain 5 none molex splitters together?
