best way to spread data over partitions when install linux
29 Oct 2005
Hi,
I want to install Ubuntu on my pc, however in the past I have just put everything in one partition (except swap space). So my question to you guys is:
How best to spread data over partitions when installing linux?
I ask in the hope that there is something that makes kernel upgrades easier / backups easier etc.
Thanks
Daven
Personally /boot and /home always get their own partitions. In my case, I usually only have one disk partitioned in ext3, so if you're talking multiple disks, that would affect my choices.
I think the only real reason I partition like this is because it's 'what I know'. I don't really think I can justify any further than that tbh.
Typically I use LVM, with separate partitions for /boot, /home, swap and /.
Then I just happily use MondoRescue to backup my data periodically to a USB drive. If I upgrade to a new version of the distro, I just install into the same partitions but keep /home intact if I feel like it.
What makes kernel upgrades hard with your current partition layout?
thanks for the tips, I found these resources so might follow bits of them as they seem to be similar to what you guys suggest but I'm guessing the first is more for servers.
http://www.linuxsa.org.au/tips/disk-partitioning.html
http://www.cyberciti.biz/tips/the-importance-of-linux-partitions.html
I'm not sure what makes kernel upgrades hard with my current layout (which is everything under /) but in the past a kernel upgrade basically broke everything!! I know it is a pretty big upgrade but was hoping for a way to make it painless.
Either way, partioning my /home and things is probably a good idea.
Thanks
Daven
