Best Way to Spread WiFi Coverage!
11 Jul 2006
Cradley, West Midlands
I would like some advice on how I can boost/spread my Wifi for as cheap as possible.
I drew this magnificent diagram below to help demonstrate my predicament!
p.s not to scale
Red box is at the bottom of the paint masterpiece is where my Virgin SuperHub currently is. Ideally, I don't want to move it as that's where all our PC's etc are.
The WiFi signal starts to bite the dust towards the end of the kitchen extension (red line), so doesn't actually reach to the man cave at the bottom of the garden, which is where I need some Internetz!
The garden isn't huge, probably around 20ft or so.
So whats the best/cheapest way to get a decent signal in my man cave?
Good enough signal to stream videos, if that makes any difference.
Not a bad shout actually, could run it alongside the fence I suppose. Theres some 50m reels on the bay for around £35. Going to have to measure up to see if it will be enough though!
Any recommendations for a switch?
Any other suggestions?
If you don't fancy running a cable you could pop an external AP on the outside of the house and cable it back to the router.
Don't mind running cables at all. Just unsure on which hardware would be best suited to the job. Switches? APs? .. would CAT5e cable do the trick as it seems to be much cheaper, or would it be best going for CAT6?
Yeah it does seem much much cheaper, so long as it streams video okay then that's great! I can't imagine it will be used for anything else.
If I can hijack this thread...I need something quite similar....but not...
I have the same problem BUT I have Cat6 cable all the way down to the 'man cave'.
I have a Gigabit switch and everything connected wired. So while I have a lot of wired I would like to provide wireless for phones, Kindle, guests, etc.
What a cheap way of making a new wireless network?
I guess an AP would do the trick, if you've already got cables laying around everywhere then thats a bonus :)
Spoken to my neighbor who also has Virgin Media with the same hub, also said how rubbish the WiFi signal is.
We don't have exceptionally large houses. Just a standard terraced house, so not sure why they are so poor.
I've ordered 50m of CAT5E cable.
Would this switch do the trick on the other end?
YOUR BASKET
1 x TP-Link 5 Port Gigabit Desktop Switch (TL-SG1005D) £19.99
Total : £22.97 (includes shipping : £2.48).
Or would I be better off having an AP/Extender so WiFi could be picked up as well as a cabled connection. Just thinking of things like iPads/Phones etc....
