Best way to start up Internet Explorer at log on?
10 Jan 2006
Bournemouth tbh
At the minute, just got a BAT file with "start iexplore.exe" in
We are on a domain, is there something I could do via group policy/active desktop?
It seems to take a while for IE to load the way I currently have it, as it would anyway.
Essentially want IE to start up the Intranet everytime our users log on
At our place, we've had to get Firefox (we use the Front Motion Community Build) to handle the intranet auto load, and I *think* its called from a batch file.
The reason being, IE almost certainly crashed everytime whilst the user(s) got impatient.
put a shortcut in the windows startup folder.
you could write a small script to copy a shortcut to all the machines on your domain.
Hope it helps.
if fact, since I'm in a good mood....
Code:
'create FSO object
Set objFSO = CreateObject("scripting.filesystemobject")
'checks to see if shortcut is already there and quits if it is
If objfso.FileExists "c:\documents and settings\all users\Start Menu\Programs\Startup\Internet Explorer.lnk" True Then
	wscript.quit
End if
'copies shortcut to users machine
objfso.CopyFile "\\servername\path\to\shortcut\internet explorer.lnk", "c:\documents and settings\all users\Start Menu\Programs\Startup\Internet Explorer.lnk"
'displays message box if there is problem with copying the file
If Err <> 0 Then
	MsgBox "Failed to copy Internet shortcut. Please contact to your system administrator"
End If
'script quits
WScript.quit
Save that in notpad as a .vbs file and you'll be golden.
You will have to change a few details, like the place the shortcut is stored in for you to copy it from.
Also, you'll have to create a GPO and use this as the logon on script. It will copy the shortcut to every machine that logs on. Job Done. :)
Hope it helps.
Can still be done in group policy.
Computer Configuration > Administrative Templates > System > Logon > Run these programs at user logon.
