Best Way To Switch Provider?
16 Nov 2002
The Moon
At the moment we currently have Virgin BB and Phone, and Sky TV. The Virgin package is costing us an arm and a leg as its 20mb, so I came to the conclusion it would probably be better to switch over to BT/Sky and get phone and internet through Sky.
Can anyone recommend the best way to go about this? I don't know whether to cancel the VM first, then apply for BT line, or to ring BT, and arrange the installation of the line etc first, then ring VM to cancel when that is activated. I'm thinking probably the latter is the best way to do it, also does anyone know if you can take your number across from a cable provider to BT?
Thanks.
