- 24 Sep 2007
What do you find is the best way to warm plates and keep them warm, and the best way to keep food warm for serving?
Thanks
Thanks
Depends what they are made of. Metal plates or even metal gilded will be an issue.Quick blast in the microwave
Andi.
It's fine - you can just wrap the metal plates in tinfoil to stop the microwaves hitting them.Depends what they are made of. Metal plates or even metal gilded will be an issue.
Andi.
Not very energy efficient, surely? Having said that we tend to boil the kettle and put hot water in them for 5mins. I wonder how that compares to leaving the oven on for 20mins? Although to be fair we're usually booking the kettle for other stuff.. veggies etc.If I'm not using the oven I usually put them in there on 100c.
Why not? I remember going round to a friend's house who was a pretty good cook. Loved hosting people. He'd gone to a massive effort of roasting a couple of joints, dauphinoise potatoes, loads of sides all dished up in the middle of the table for 6 of us. We all sat down and my girlfriend and I noticed straight away that the plates were ice cold. By the time you'd dished up all your food from the selection, it was cold!I'm not too fussed about a hot plate though.
Pop them on a radiator before you eat, that's what I do and it works a treat.
I'm one of those odd people who don't like hot plates, we don't have slave kitchens a few hundred yards away these days. Food is 99.9% of the time to hot even with a cold plate.
Thanks
Clearly to hot then if you have to spend 5 seconds per mouthful blowing on it. How can you not get that.No idea what you mean by 'Food is 99.9% of the time to hot'; assuming the flavour isn't impaired and it's designed to be hot food, I don't see how it can ever be 'to hot'. You cut some up and blow on it when it's on your fork...not too hot in about 5 seconds.
Only for the first few mouthfuls until the food's no longer piping hot. Better than too cold.Clearly to hot then if you have to spend 5 seconds per mouthful blowing on it. How can you not get that.
And what logistic issues at dinner parties serving many people.
Very.How hot's piping hot?
