hi, all i've ever used is IE and was wondering if its worth changing to another browser and which is best.
also can i use IE and another browser at the same time or is it a case of using one or the other.
Common opinions of browsers are that Chrome is fastest, Firefox is the most customisable and Opera comes with the most built-in functions. Whatever you decide to use, it will be better than IE![]()
For someone that isn't interested in them though like myself, I honestly can't think of a single advantage that other browsers have over Internet Explorer.
Other browsers are standards compliant. That's a reasonably large advantage in itself. Other browsers are beginning to support CSS 3 - IE? No. I could go on but you get the drift.
I have come across a number of your posts where you end up commenting on Internet Explorer which normally goes along the lines of what you have just said above.
What sort of things can other browsers do that Internet Explorer can't when you're just searching for things on the internet?
