Best White Case for £80?
22 May 2007
Sorry, should have mentioned size, yes ATX please!
Like both of those Doomedspped. The C70 is nice but I don't know if its too "Gamery" if that makes sense? Usually try and avoid 'gaming' cases and prefer smart looks. Hence, I'm not a fan of the Phantom
The 600T is a bit too far over budget!
Thanks for the prompt replies so far!
ah this links into my question i was going to post up .... i didnt like any of the cases that were in white so i decided to get a black one and im going to spray it ...now any of you custom project guys think rattle cans will be ok for a solid finish or should i invest in a airbrush ... and if so what paint should i use in the airbrush?
I have the white Phantom, but im looking to get a new case. It does look really good, but I wanna get the Bitfenix Ronin.
I really like the white Shinobi, really smart looking case.. that not appeal to you?
On the shinobi I don't fancy the mesh lines on it really. Nor did it get that good reviews.
At this moment in time I've moved away from a white case. So indecisive!
