Best widescreen TFT for Xbox 360 and PC
28 Jan 2006
I've been looking for a good widescreen TFT for my pc and xbox 360. Requirements are VGA and DVI inputs as well as superb picture quality. S-Video input is plus for PS2.
I have listed some of the candidates:
BELINEA 10 20 35W
Dell 2005FPW
ACER AL1916W
ACER AL2032WA
FSC SCALEOVIEW W19-1
Samsung 940MW
VIEWSONIC VA2012W
Or you could suggest something better.
My limit is 750 euro (900 USD, 512 GBP)
Any opinions as which one is the best (picture quality, colors, ghosting, overall)?
I'm currently using my Dell 2005FPW for PC (DVI) and XBOX 360 (VGA) and have absolutely no complaints.
Picture quality is excellent and zero ghosting.
Heres some pictures I took a while back of the 360 on the Dell:
Guru, how are you actually connecting your tft up to your consoles? are you using some kind of convertor?
I'm using the Official MS 360 VGA Cable to connect the XBOX to the monitor.
The Dell 2005FPW has both DVI and VGA Connectors at the rear of the monitor, which you can switch between the 2 on the fly via a button on the front.
Interesting... How about Belinea? Seems like Belinea and Dell are the best ones at the moment.
Also I haven't been able to find much info on Acer AL2032WA. Any ideas how that fares against Dell and Belinea?
I'm using the Belinea exclusively for the 360 and it's superb. Can't really fault it tbh. As with the 2005FPW it has VGA & DVI connectors at the rear which can be toggled via the OSD. Can't see any ghosting and I'd be gutted if I did.
What resolutions do you guys use on your xbox 360?
I have Viewsonic VX912 on my PC and it really doesn't scale picture very well.
Does either monitor also have S-Video input?
why such a low res? Or is that the best an xbox can do ( I was imagining 24" dell users where on optimum res, but im probably wrong) I am on the hunt for xbox 360 vga cable
1360x768 is the highest possible resolution using Xbox's VGA-cable.
