Best Wireless Adapter & Router
ive
ive
16 Jun 2004
Cork, Ireland
ok...after getting my be-loved new ps3..ive decided its time for a wireless router..dont really know what the best all round solution is..pc will be wired..ps3 downstairs..so i just want something reliable..and averagely priced..after all 700eur gone on the ps3 :D
cheers, ivan
Im using the Belkin 7633uk4
It works without any problems connecting wireless to :
Xbox360
Wii
PS3
It has a good range and never seems to loose connection to any of these devices.
Using Vista wired on 1 Pc and XPsp2 on another with all 3 devices above.
Ive also never noticed any major internet slowdown when using torrents either, The netgear i had previously would slow down quiet a lot , but newer models may have overcome this
In the same boat as you ive, i'm not too clued up on the wifi end of things tho. Was looking at this http://www.overclockers.co.uk/showproduct.php?prodid=NW-083-NG not sure if this is the right sort of thing...
Currently on a DG834v2 (wired) with a long cat5 lead trailing across the living room carpet :S PS3 keeps losing connection to the net, it only stays connected when i remove the ethernet cable from the modem thats for the PC connection and obviously i don;t wanna keep doin that everytime i want to go online with the PS3.
I'll keep an eye on this thread and see what others suggest for ive (and lil ol' me) :)
