Best Wireless ADSL Router for around £40
25 Jan 2003
As title really. Im a bit out of touch when it comes to routers. A friend needs a wireless ADSL router for around £40.
So what can you knowledgeable people suggest?
Cheers :)
£40 is pushing it a bit. if you could stretch to £50-55 then you'd be looking at the WAG54G.
Do the job nicely. But DO make sure you get the 2nd version. First version is mostly discontinued but not really worth it's weight in recycling.
The NETGEAR D834G (available for £59) is far superior. I've had a load of WAG54Gs and really didn't like them.
Linksys wag354g is available at just above that price at the moment with a usb or pccard adapter. Its been more reliable than 2 or 3 other wireless routers I have tried recently and its cheap.
