Best wireless adsl router?
10 Aug 2006
Warrington
Whats considered the current best wireless & gigabit adsl router in terms of wireless signal?
I currently have a 7 year old netgear dg834 v2 and its wireless signal is awful. Was thinking maybe this?
What wireless card are you using? Buying a 'N' standard router doesn't give you many benefits unless you're also using an 'N' standard wifi card to take advantage of the features.
A wireless N card will be purchased aswell.
No current fave on the wireless router front then, ah well I will just have to take the blind plunge
