Best wireless bridge to connect BT Hub wirelessly to a load balancer
18 Oct 2002
Sandwich, Kent
Hi there,
I've been through my collection of old wireless repeaters, access points and nothing seems to want to work properly in WDS mode. So, I need to pickup something that can connect to my home hub wirelessly to connect by BT Hub's internet connection into a load balancer.
Ethernet cable isn't an option at the moment, nor is poweline - so I'm having to bridge this wirelessly. Performance isn't a concern either.
Any recommendations for a simple wireless repeater that I can use as a pure wireless bridge?
If performance doesn’t really matter then I’ve used one of these in what they call “client” mode that acted as a reliable (but slow) wireless bridge: TP-Link TL-WA901N. About £25 from memory.
Thanks. After about 4 hours messing around with this, I just managed to get a firmware update for one of my old TP Link AC1200's and got it running in WDS mode.
Much success.
If anyone else tries creating a WDS bridge with a TP-Link Archer C50 AC1200 (V4) - once you've updated the firmware, you need to reset to defaults before the option shows up in the 2.4G and 5G menus.
