Best wireless controller for PC
27 Mar 2016
Bristolian living in Swindon
Hi all
Just looking to tidy up my desk abit and have a few wireless bits for my PC... Can any recommend a reasonably priced controller to use? I only play Fifa, ETS2 and Project cars
Thanks in advance
Xbox 1 / elite controller. Get the wireless dongle and your set to go. Works flawless for me and any game that has controller support will always support the Xbox 1 controller in all the games I have used.
The normal Xbox 1 controller had a revision a few years back and also can connect via Bluetooth without the need for another adaptor if your pc has Bluetooth, but I have found that connection a bit finicky.
Brilliant! Thanks for the responses I was looking at the wireless xbox one control will have to check out the Elite one
