Best wireless router for £50
18 Nov 2005
Leamington Spa
I've settled with an ISP for my student house, decided on a NTL 10mb connection (desoite my previous worries about cost, they work out cheaper than adsl for us). Now whats the best cable router for £50? On the wireless side of things, it'll be used to connect 3 laptops for web browsing, no p2p. As for wired, it'll mainly be used for online gaming and p2p.
Was considering this: Belkin 125Mbps Wireless-G Router (F5D7231UK4) (NW-021-BE) (2nd one down)
I have this one at home and have had no trouble with it, even with heavy bittorrent use over wireless. I just want to check there aren't any better options i'd overlooked.
I personally have preference for Linksys. I've been using their products for years without problems. I have the WRT54GS and never had any problems, its on the same page as the Belkin.
i like linksys for home user kit, but anything that use's linux firmware is genrally okay.
What benefits would i get from going for the linksys over the belkin router? Would i be loosing any speed by going for the 54g over the 108g when i'm using centrino laptops to connect to the wireless?
