- 26 May 2008
Hi all,
Running a Q9550 at stock within a Gigabyte GZ-X1 case with two Vipers up front one Viper at rear, CPU cooler is a Scythe Kama Angle.
This kept my old dual core nice n cool but recently re-installed with a Q9550 and some MX-3 with two re-seats and current temps still seem off? It has put me off OC'ing so far.
Core 0-41*C low
Core 1-27*C low
Core 2-40*C low
Core 3-36*C low
Now the Scythe only has the push fit option, was wondering if buying the optional screw down backplate may help, it was initially bought for quiet cooling.
So now thinking? What if there are better CPU cooling options out there, preferably with out the push pin connection and no higher than the Scythe Kama?
Core 0-41*C low
Core 1-27*C low
Core 2-40*C low
Core 3-36*C low
