Hi,
Recently built a small form factor system made up of the following
Whole system runs great for 95% of the time, the only issue im having is when using Photoshop or Lightroom. It seems so much slower then my old full sized system which had a i5 3570K with a Nvidia 660 GPU. I knew the small form factor would be a compromise but was hoping for a little more when pushed.
Ive been looking at swapping hte CPU for either
i5 5675C
or
i7 4790T
Would either be worth it, ie will they give me the boost im after?. Ive looked on all the GPU comparisons and it seems gains are to be had, but real use feedback would be great.
- ASRock Z97E-ITX/AC, Intel Z97, S 1150, DDR3, SATA III 6Gb/s, SATA RAID, PCIe 3.0 (x16), DP/DVI/HDMI, Mini ITX
- Intel Core i5 4590T, 1150, Haswell Refresh, Quad Core, 2.0GHz Base, 3.0GHz Turbo, 1150MHz GPU, 35W, CPU
- 16 gb DDR3
- Transcend 2242 256 GB SATA3 Solid State Drive (to go in the m.2 slot of motherboard)
- 250GB SAMSUNG 840 SSD as photoshop drive
- 1tb WD blue drive for everything else
i5 5675C
or
i7 4790T
